Another day to work on the truck. I had a few hours today and did alittle more burning on the top. It doesn't look like much got done, but I guess thats what happens when you have to fight the steel to fit like I want it to.
I finished burning in the drip rails and got the fill panels made and welded in where I had to split the top to stretch it. The rest of the top lined up so nicely when putting it back on that I knew something was going to give me a fit and today I found it.
The front and rear roof lined up almost perfect for the fill panel on the pass side, so close I could probably grind the weld, prime and paint it with no filler. The drivers side....not so much. It was off by almost an inch, I had to twist, hammer, grind, etc just to get the drip rail to line up. The cab had a big dent on the drivers side rear corner of the cab so I'm sure thats what caused the problem, After some "negotiation" with the roof, I was able to get the drip rail welded in and at least be acceptable, more body work than I was hoping for in that area, but oh well, cant win them all. So after that I put on the fill panel and finished connecting the cab back together.
After that I took out my 1" strap and made the 4 pieces to support my skylight opening. Cut them to length and clamped them in place, I lined them up with 1/2" overlap to give me room to weld to and smooth it out. I think it turned out pretty good. I couldnt get the strap to quite hold the arc I needed on the front so I ended up making a small relief cut in the very center of the roof to get it to lay down evenly. I think it turned out pretty nice.
What do you think about keeping the clearance lights on there with the open roof? If I don't keep them I am thinking about making a visor for the front out of an old semi heat shield that I have laying around, its all stainless and has holes about every inch.
I threw one of my seats inside to climb in and get a feel for it as well. The seats are out of an old boat. I will end up just using the fiberglass shell they are in and having some flush cushions made up for them instead of the bulky old pads in it now.
The windshield opening is about 6.5" now, I ended up taking about 6 inches in the rear and about 7 in the front to get everything lined up.
Now for the pics.....
