earthman
Excellent! Some lights now.
I think it'll be fine once I put some shocks on the back, and fix the dragging brakes. It was almost rolling straight down the road, but with both front brakes dragging, and with that right front brake dragging real bad, it pulls a bit to the right. The driver side upper ball joint is real bad too.Hows the steering and suspension feel?
It would be good to see you! I've been considering a road trip to see some of the rods from RRR. Of course it can't happen until I get finished. It sounds like a good vacation to me.The details are coming together nicely. If I only had 2 or 3 miles to go to see it I'd be there in 2 or 3 minutes.
Might be spending part of winter out your way next year.
There are two or three different sized diameter propane torch bottles that may work for tail lights...headlight buckets look good!
See Earthman, I told you he wanted searchlights.
Actually, 8 liter I think you're on the solution. They look proportional. Do you have a plan for the lens and reflectors?
My first thought is that you might be able to find the correct sized magnifying makeup mirrors at Walsomething for the reflectors. Mount the bulbs in front of them.
I was originally thinking just that. The only you-pull-it junkyard that was close enough to be accessible, closed down a while back. That, and I priced tail lights for a friend a while back, and they wanted $20 for each one I think. Add the entry fee, and light bulbs, reflectors, pigtails, and it's getting to be near the price of new. I'm not sure though. I might just try to get to a yard and do some looking around. Maybe I can get the housings and bulbs/pigtails for nearly nothing, and come out way ahead.All you need for headlights should be an easy junk yard find. Just fab some mounting brackets to center them inside the buckets.
It just seems like somebody would have a kit with adjusters and bulbs, ready to go. Maybe I should market that.
Yup. That's nuts.I'm just speechless about that one.
