8literbeater
Can you feel the 1630 drop off - is it pretty big bog or hardly felt?
I think I am/was confused about the air/fuel number. I thought bigger was richer and you were leaving it a little rich to keep it running cooler. Why leave it lean?
I forgot the history on that engine - has it had a valve job? Do they make turbo cams for that engine?
$95 for 12 runs seems like a smokin' deal.
In second or third gear it's seamless. In fourth gear you can just feel it. If you were riding along, you probably wouldn't notice it unless I told you.
The air/fuel ratio is [parts air] to [parts fuel]. 15:1 is more air than 13:1, because the air number is bigger for 1 part fuel. The thing is, with propane you don't get any cooling by running rich. It's a dry fuel, so there's no wet "mist" to carry away heat. Anyway, the EGT didn't go over 1000°. Staying lean will hopefully err to the side of better economy.
All I know about this engine is that I had the head off, and everything looks good. The compression was normal, as I remember. I'm sort of winging it.
The only turbo cam I could find is an Iskenderian Turbocycle-A.
They sell it in a kit with lifters, springs, retainers, locks, valve seals, lock nuts, and a new cam gear.Application: Maximum economy/torque. Turbocharged. Up to 7 PSI Boost. Smooth idle. Stock converter. Std. axle ratio. Up to 650 CFM Carb.
http://iskycams.com/cart/index.php?main_page=product_info&products_id=1284
It sounds like a good time to me.
I was on and off the dyno in under an hour. He said he could probably do your Chevy in less than two hours.
