Today turned out to be install day. Got a buddy to help me swap the hatch over to my car, that sucker is heavy! Put it on, was slightly out of alignment, but close. After I finished putting the 8N tractor back together after a fuel tank cleaning and coating, I went back to the hatch alignment issue. Had to remove an interior panel to get to the body side of the hinge mounts, loosened them a bit and pushed and pulled until it was very close, as close as I could get it anyway. Also adjusted the pull down latch, that helped a bunch, too. It's a little proud to the rear, but nowhere near as much as the other one was.
Then I started putting the spoiler on. The two front holes were easy, there was a factory access hole there, just had to drill the holes. The back two though, I set the spoiler on and marked the rear holes, then drilled them. Since there was no access holes there, I've got to get a hole saw and put one to get the nuts on, my step drill wasn't large enough to get the lower hole large enough with out the top one being too much oversize. So, for now, I just put the front nuts on. It looks great! Forgot to take any pics, I'll get some in the morning....
