It's been a little bit since I've done any updates on Dans car, mainly because all the stuff we have been doing isn't really post-worthy...........just those little jobs that are a pain, but need to be done.
One thing we have to complete soon is getting the steering box mounted. He is using a Flaming River reversed Corvair box, just like his Brother and I are using in our T's. It is about all he has room for with the 455 Olds taking up so much space, but they work well and are fairly compact. Problem is, we can't mount the steering box until we get the steering column installed. Otherwise we have no way of knowing what angle and all to mount the box at. So, we have been working on putting in the steering column.
Ford simply bolts their column to the bottom of the dash, but that wasn't going to work for us because Dan is only going to run a steering shaft with no outer tube, pretty much like I have my T done. Plus, he is going to have a U joint at the bottom, so the shaft has to be supported not only at the top but at the firewall too, so it won't flop around when turning the wheel. We kicked around a bunch of ways to do it, including running a piece of 1 x 1 box tubing around the bottom edge of the '32 dashboard. But yesterday at lunch Dan came up with something else, and it made more sense.
The pictures below will show what we did. Essentially, we made two side support brackets out of 2 inch channel and bolted them between the door jam and the firewall. Then we made up a crosstube from 1.25 round tubing and tied the master cylinder bracket off of that. Now we had a strong spot to mount the top of the steering shaft, so we built a bracket with an adjustable heim end at the top, and a flanged bearing at the bottom, bolted to the firewall. The steering shaft can't wobble at all mounted like this.
We made the whole assembly bolt in, and welded nuts to the backside of everything so we won't have to fumble around trying to install nuts and washers under a tight dash...........simply put a bolt in and tighten it down. It takes a little more time to do it that way, but so much easier when assembly time comes. The reason we wanted it all to bolt in was so we have nothing in the way when we paint inside the car.
Here are some pictures of what we got done this weekend.
