I was talking about the breakage on this tractor and hitch was shown wrecked in a previous picture. Well here's what we did to fix that. 'Pic 1'
I've been working on the gas tanks for a while now so here's the story on that. "pic 2'. I sealed up the tank except for the small exit bung in the bottom and put my air chuck in there to pressure up the inside of the tank. I had run my hands over the tank top to get the low spots figured out and then marked them with a felt pen. With the tank pressured up as much as I dared I started hammering around the low spots with a plastic hammer.
'pic 3' is showing that I could not make the tank perfect with my air-pressure/hammer trick, but I got it better than before so I still had to put body filler on the top of the tank. Here is 'pic4' the tank in primer for the third time, with board-sanding in between. I had also cleaned the tank out, dried it, and then added Bill Hirsh Tank Sealer and sloshed it around in there.
'pic 5' is part way through the body work and priming of the 'starting' gas tank. In the old days the tractors ran on distillate, [a cheaper hydro carbon, more like diesel fuel], but the engine had to be started on gas, and maybe warmed up a bit first, then switched to distillate. There was an extra, small tank on most tractors to hold this 'starting' gas, but neither of my tractors had anything left of the small tanks so I got to make one in any shape I wanted. When I was hunting around for ideas I spied my pile of extra, modern, air cleaners and built my own small gas tank. 'pic 6' is the finished starter gas tank.
