I think it'll look too bulky. You may be able to make it look good after a lot of work, but odds are, no matter what, it'll still look like a wheelbarrow. You can find something better. I do like the grill idea though.
The wheelbarrow is too big for a grille shell. Makes a great firewall trans tunnel though. For a grille find a classic tractor grille can't go wrong there.
I have these 2 for sale.
grill shell...
What if you sliced up 4 oil pans welded back together as quadrants to make 1 big grill sized oilpan then cut the center out...
How about a water heater tank or a 30 gallon drum split down the middle and tilted back at an angle with the top and bottoms mitered parallel with the ground like a templar's shield..or capped off rather nicely at the top...
The weirdest rattiest most inappropriate idea i could come up with was a stack of computer monitor housings with the centers cut out and the tubes removed or leave the tubes in and play a video of a running engine...running in hell [cl
I took some pics of a mock-up front end using some AT tires and my wheelbarrow...I wanted to see how bulky it may or may not look...I'd do the same thing with a tractor grill, if I had one.
Anyone want to change their vote? haha
Am I going to be able to fit a radiator, big enough to cool a Detroit 4-53T, inside and behind a tractor grill? Should I be looking for a radiator before I find a grill? "Cart before the horse???"
Actually I think you could work with that. I love the herring bone idea. The tractor grill can look ok if you find the right one but since I am an old farm boy I always think tractor when I see one. Most of them just sit too straight up for my taste. Some of the old Oliver grills are way cool but you'd never get a big enough radiator in most of those for the 4-53.
If those are the size tires you'll be using, I retract my 'too big and bulky" statement. I think it'll work, but it'll take some work. If you just cut a hole in the bottom and weld in a flat grill - it's not gonna be enough. You'll need to add some flare - either curve the grill or round the edges of the hole, or both. But the extra work will make a BIG difference.
I had to Google "Whippet grill" to know what we were referencing...sorry, "new guy".
If I pull this off, it might start a new trend...eh?
The calf pen stock is 3/4in. O.D. round pipe. I think that I might be able to make a jig to bend them into a slight arc.
I was also thinking of rolling the inside edge of the grill opening, but I'm trying to decide how. One option is to mark the outer edge of the final opening, then mark a concentric circle/ outline 2" inside the final opening and cutting that inside line. Next I would cut relief cuts creating 2" wide tabs that I would then roll towards the outside like a sardine can...working my way around the entire grill opening.
I hope you guys can see what I'm talking about..it's hard to draw that on the computer.
As I am thinking about what I can use as a substitute for the 3/4" pipe, my first thought was 3/8" rusted re-bar. And then use 1/2" re-bar for the "rolled opening".
Is using re-bar "cheating"... or just over used?
Another option would be to use 3/8" round rod fencing stakes. (Sticking to the Farm Rat theme.)
And as a side note, here is a link to the rims that I am considering for the BF Goodrich A/T truck tires.
So, I recently tore down a barn that was ready to fall down on it's own, and I was able to remove the headstalls from all of the cow stanchions. I was planning on keeping a few and then scrapping the rest. I have them laying in a pile along side the driveway. And then it hit me, I could use the curved sections to build the "rolled" edge for the grill frame!
I don't know why I didn't think of using them before.
