echnidna
so your concept is mooo--ving along
I've never actually used these yet but here's what a little imagination can do. Take an old set of wall mount lamps
Rig up an arbor with a piece of reddi rod and wooden discs so you can put them in the drill press, polish the appropriate amount, install sealed beams a viola!!
If you go new, I'd go with the #4 before #1. But really, I wouldn't go with either if it were me, unless you could figure out some good looking old school style buckets to put them in.
Am I going to be able to fit a radiator, big enough to cool a Detroit 4-53T, inside and behind a tractor grill? Should I be looking for a radiator before I find a grill? "Cart before the horse???"
I appreciate your enthusiasm, but you said it - Cart before the horse is exactly where you are.
None of these ideas will mean squat if they aren't coupled with a design that flows with good proportions. You can't say what grill or lights or most anything else will work without a body, frame, suspension and correct wheels and tires at ride height. That's the foundation. Think about a house - You can build the neatest looking roof in the world but it's no good if the walls don't fit under it. I hope you get what I'm saying. It's fun to daydream, but without a solid design to start with it can turn bad quickly. THAT's how you end up looking like the "wanna-be" guy in a WTF type ride that you are wanting to avoid. (see the IH pickup/Grand Am fusion nightmare)
Well built, well engineered stuff is easily appreciated even if it's not your style. Junk slapped together for a "theme" or any other reason is usually just that - junk. Some stuff sounds good in your head but...
