Well whoopie doo I doing tiny little operations to get this engine running this summer. Lots of changes from turbo, ECU's to a carb, and regular distributor with points. I need something I can fix on the road hopefully Waiting for an expensive tow truck and then high charges for diagnostic machines etc. There is no end to the amounts a garage can charge you for.. When you are stuck in their territory. I've been there its not cheap or fun... I installed the starter and started to set up the solenoid and wiring. But I think I want the battery in the front between the radiator and the engine down low I have plenty of room and I never liked opening the hood on a car and the 1st thing you see is a darn battery hanging off the fire wall corroding everything else near it.
