update 3:15pm: l made a few phone calls, yep, it would turn reveres, so l have to figure out a way to fix that if l run a transfer case.
one option the people l talked to suggested TC with reverse, run the reverse gear, l go the right way. bunch of shops and 4x4 people have not ever heard of one so l do not know if they even exist.
one other said if l mount the re-end upside down it will work, but l am not to sure about that curing the problem, and then there's brakes, vent and other stuff to consider. a lot of people have done it, so that is probably the answer AND all info l found says use a 9" or 8 3/4''.
did on line research, seem a lot of people have done it, says the only draw back is the rear-end is not quite as strong but, since l am using a 3OOhp SBC it should hold up fine.
l have the 8 3/4 out of a mid 197O's truck, near as l can guess it's a 355.
Later
plans coming along quickly.
Later
