I guess I dont understand, which isnt unlikely.
if the transfer case turns the front and rear driveshafts the same way, the front axle has to "reverse" the turn. so if you cant use a rear axle because it turns backwards, why not use a front axle with locked steering?
flipping upside down on the centerline wouldnt change anything about rotation of the driveshafts, it would just change where the oil sits in the case.
