sgtpontiac
Older, Wiser and Still Buildin'
Murphys law.... too bad on the Rad...
Now, finesse the rest of this build like you would a rack of pool balls....[cl
I had to give that up when they told me I didn't fit into the requisite Speedo.Oh.... That kind of pool.
I thought perhaps skip was on a synchronised swim team..LOL
Waiting for the fire up....
We made engine noise this afternoon.
My buddy Larry is visiting, so we went out to stare at it for a bit. We found a couple small leaks. The plug in the radiator got another turn, and the on/off switch for the fan had a little tiny bit of a weep. So we hooked up the battery, and I cranked the engine. Didn't fire right up, so I went to get the starting fluid from the front garage. With Larry armed with the starting fluid, I turned the key again, and ROARRRRRRRRRRRRRRRRRR!!!
Messed with the idle a bit, and it settled down. Found that I also forgot to tighten the fitting on the transmission cooling lines. Easy fix.
I think its time to rent a trailer, and take a trip to the DMV.
After I put the grille back in again.![]()
