billy
Motor mouth ratchet jaw!
Yep
I will pay you to bring my crap and use the hotrod as a daily driver
Things could be a lot worse.
is the high pressure fuel pump
from the dealer here it is $3800 installed at the shop
I am putting the truck in storage until I can buy my own part
for $1000 and then have it installed for $500
my wife is coming to get me
I am amazed that I have not gotten ****ed off about this
Either I am calming down in my old age or just getting better at controlling my temper
I would say having a good friend like I R Pops helps keep the stress level down considerably.
Does the lift pump check out? A lot of times those go bad and it kills the injection pump.
from the dealer here it is $3800 installed at the shopAre you running gauges?
I had a vp44 go out on my '98. I boutpght it and replaced myself. It was a PITA as they require s "special tool". My special tool ended up being bars, ratchet straps and a tree.
Like others have said, the lift pump going out will kill the vp44. Problem is the vp44 can run fairly strong for so,e time without any indication that the lift pump isn't working.
Lost the lift pump in my 03 and put in an air dog. It lasted about a year till a seal let fuel into the motor frying it.
Easy fix, but frustrating.
$3800 seems awfully high for the vp33, even with the parts being $1200. Labor isn't that bad.
What did you find out Billy ????
i didnt even think about removing the box.[S
now i am back home in nebraska scraping money together for the vp44....
