Headlights and mounts
Worked on headlight buckets and mounts. Fit the headlight mounts in the bucket, shrunk the headlight bezels to fit the lights tight so they would hold the lights in. Had to reverse the mounts because the studs aimed too far back. I added 1/8 ring behind the the bezel so I can blend the bezel into the bucket wit body filler. made mounts out of 1/4" plate that I pressed into a cup shape to fit the ball mount of the bucket. then I ran round stock to the rear bung of the shock mount. I know they are way overkill but it was the only way I could make them match on both sides, then I added the curved piece of round stock at the top to tie it together. Still have some holes to fill and welds to finish up. I think they came out pretty good so far.
