Well I guess it's started
Torch, got ya. no acounting for some peoples idea of cool [S
[P
Old Iron, clecos are cool, used to use them when i repaired aircraft but the gov. bought them then.
Be Safe
What a chour
I sure hope this turns out [S
    133.1 KB
Is it just me
Picked up a 70 roof for the project, my gmc was filled with lead on the cornors and the chevy was filled with bondo [S
Make head way with the side pieces yesterday with daughters help.
Stay tuned[P
    121.8 KB
    92.7 KB
A little update. Have'nt gotten much done, now that i'm retired i don't have any time [S
All four cornors are on and the gaps are filled. Looking for a roof big enough and the right shape to fill the hole [S
All good ideas
But, I'm going a way i've done before. Picked up a donor top, 70 skylark, i'll use a lot of the skin here and more on the bed. This is about where it will set. i ordered a new flange tool, punmatic my old one was a hand job[Si'm getting to old for that. i'll flange the car part and set the new piece in and weld the seam inside and out[S
i'm thinking it will keep the roof curve pretty close and yes it does add about 3/4" to the hieght.
So far so good??[;)
    220.8 KB
    97.7 KB
    136.3 KB
Have you done that procedure before on a roof? Just curious. Seems to me welding a big panel like that, of that gauge, inside and out, is asking for a lot of chances for warpage. What I'm saying is, if I tried that it would look like a Hot Wheels stunt track when I was done. :rolleyes:
If I ever do one again....I'll do the same thing....
I found that welding at the curved ends of the roof, sides, front and back, the metal did not distort at all....it was while welding the fillers in the middle where i ran into all the distortion....If I did it again, I'd do exactly what soltz is doing.....at least on later model stuff.....JMHO...live and learn....:D
Good advise all around
Sam, yes on a 56 F100, turned out not to bad [S The key is slow and steady, let it cool or cold compress to shrink it back in shape. Also the flanging should help by giving it a stiff line to follow. I'll keep a photo record as i go [;)
Thanks sgt it's good to get positive feed back and yes the filler pieces were a bitch :mad:
The 56 finished with my beautiful bride[cl
can't seem to get the picture to load[S I'll try a seperate post:cool:
