Some one turned my bronco on its side!!!!!
View attachment 181741View attachment 181742View attachment 181743
Love to do that to my Samurai. Jim
So much better!!!!!Love to do that to my Samurai. Jim
What show Nov 10-11?Now that it's kooled down here in Cantral Tejas I've been able to start tying up the last lil loose ends on the Rambler! Got it running right but still need to do a lil more wiring work. Wired the neutral safety switch on the shifter yesterday & still need to hook up the universal turn signal switch. Since I lowered the front end I also need to get some shorter shocks & I'm headed into town after I suck down an energy drink... haha! One of my fav car shows on Nov 10-11th & I can't wait!
That is a tough one. I so wanted my boys to get into the hot rods but it never took. The grandsons are showing interest so I'm hoping that will take root. If it's going to roll it will- nothing easy about being a dad or grand dad for that matter LOL. Things could be much worse so at least we got that going for us!!!On leg room, most of ya'll know the early cabs are tight and we tend to make them tighter to make things cooler. My grandson wants my 31 when I go. Unfortunately, he's 16 and over 6' tall right now and I don't think he's done growing yet. I've let him drive around the property and driveway around here but noticed he's actually jammed in so tight he can't move well enough to drive safely. I told him I won't let him drive it on the road and probably pissed him off. He's having a little trouble focusing on what needs to be done. I have trouble getting him involved in projects around here. We have a couple of projects going, but his attendance and drive is lacking so they sit, mostly in the way. I mentioned that the cab could be altered to make it better but with his previous enthusiasm issues I wonder if it will ever happen. We could stretch the cab and lengthen the frame(maybe not real necessary). I just wish he'd act like it was important enough to dive into it.
When my son first told me he wanted to build a hot rod, I got all excited. We made a trip to a local junk yard that still, at that time, had some old projects to buy. He picked out a 50 Dodge 2 ton truck as his first project, so we drug it to my shop. He started off real fast, we found a frame he stripped and repainted, and we stuck the cab on the frame. Then suddenly, he lost interest.That is a tough one. I so wanted my boys to get into the hot rods but it never took. The grandsons are showing interest so I'm hoping that will take root. If it's going to roll it will- nothing easy about being a dad or grand dad for that matter LOL. Things could be much worse so at least we got that going for us!!!
If you do buy a new computer, also purchase an external housing you can install the hard drive fromm the locked up computer in. Then use it as an external drive, search for the "photos" file, or whatever you named it, then copy where you want them.On a different note, my last week, actually started about last Tuesday, was interesting.
Since we have been driving the truck, the Plymouth coupe has been sitting around. We put it up for sale last spring (2023) because we knew we would be driving the truck everywhere (new toy) but did not get any action on it. The license plates expired last April. In IL, the $151 plate fee would have only covered the old plate until it had been dormant for a full calendar year. We can buy what they call an Extended Antique plate for $50 a year (drive regularly between May 1st and Oct 31 with no restrictions), and the plan was to get those plates after the old plates were expired for a year. I went and got those plates on Tuesday. Later that morning I decided to drive the coupe to the gas station to buy some gas. as I pulled away from the gas pump the motor died. It restarted but died again. Nothing but crank over, and of course, no tools. Some kind sole helped me push the car away from the gas pumps. I called my wife to come and pick me up so I could get some tools. By the time I returned, it was nearly 90 degrees and I was working in the sun. I found I lost spark, but sure was not into doing anything about it there. AAA towing to the rescue. I was back home and the coupe was pushed into the garage in about an hour, but I had someplace I needed to be the rest of the night.
Wed morning was mowing day here. When I turned on my computer Wed afternoon, I typed in my pin number to start the computer, it is usually one of those quick things and I don't often pay much attention (in case you haven't noticed, my typing skills are not very good). I was kind of in a hurry, and I typed in a wrong letter (not the first time I've done that), so I typed it in again, pretty sure it was correct, but I was informed it too was incorrect. Then I started second guessing if I typed it in wrong again, but I wasn't even sure if I was typing in the correct pin at all.
That resulted in Microsoft locking my pin. Things went down hill from there. As a 2nd option I could use the password. I had that written down. I very carefully typed that in, only to find out it must not have been the most recent password. I hate it when I need to keep updating passwords.
That locked the system. My last option was to go back to the original phone number the program was opened under, and they would text me a code to get in. That number was a land line we no longer have (they couldn't have texted a land line anyway).
The 4th was a busy day around here. We did enjoy the craziness of an extended family gathering.
Friday was spent working on the coupe, To start out, I turned the key and it fired right up! It ran a couple minutes then died. wouldn't restart. No power to the coil. I have the fuse box hidden behind a cover I had to remove to even check the fuses (what was I thinking back then (2012) with the panel pulled, I also had access to the steering column (the switch is on the column). Everything checked good and when I turned the key, the car started up again. It ran a couple minutes and died again, no voltage to the coil, but all the fuses had power, and the ignition switch functioned (didn't start that time). The problem had to be between the ignition switch and the coil. Of course, to gain access to that wiring is going to be a pain. The car has electronic fuel injection, so that adds more questions.
I have a known good computer, it was pretty easy to plug in and test. No difference. I have a few good relays, those are easy to swap out. Nothing. Checking the wire harness is it. There was a lot of stuff to disconnect and move to be able to remove the 3' long 1" diameter wire loom full of wires that extended from the passenger side where the coil was to the driver side where cowl where the wiring enters the passenger compartment. I spent several hours doing that, only to find the wiring was flawless. I did find another relay I didn't see, which I changed. Everything would need to be reassembled to see if the problem was fixed. I just was not ready for that. I did call my mechanic buddy. He suggested that maybe since the car hasn't been driven (it has been started and has been moved to mow around), maybe there was a problem with the fuel pump or the wiring to it, under the car. I reassembled the car (except the fuse panel cover) and called it a day.
Friday evening I dug out my wife's old lap top (which I'm using right now). But Saturday was another extended family reunion day.
Sunday we spent the afternoon trying to get Microsoft to unlock my computer. We didn't provide enough information for them to think it was my computer. Looks like a new one will be coming. The old one was really old, and the thing I am the most sorry about is I don't have access to nearly 900 pictures (including my 48 coupe and my 49 truck builds). At least I've been able to get on the emails and most of the web sites I visit often.
The good news is I got the coupe to run! I put it up on jack stands and checked the wiring to the fuel pump it was OK) As I was leaning on the fender wondering what the next step was going to be, I noticed a smaller vacuum hose disconnected from the brake booster vacuum supply line, so I plugged that in and started the motor. It fired right up, purred like a kitten for more then 15 minutes. While it s running, I put the fuse box cover back on, took the car off the jack stands, put the tools away, and drove the car out of the garage. Then I took it for a 20 mile cruise. It was fun getting back in it and actually driving it this afternoon. I don't know if that vacuum hose was the cause of the problem all along, or if it was that last relay I found, and the vacuum hose got disconnected while I was messing with the wiring all around that connection. I'm going to lay the blame on both. At least I know the wiring is still all good.
I will probably be buying a new computer next week. We can appeal to Microsoft again, but I'm not expecting much help from them.
I'm looking for a desk top computer (my monitor has some issues as well, will probably replace it at the same time), probably don't need a big powerful unit, I just surf a few message board a few U-tube videos, and such, no gaming or big time video stuff, but if I can get an SD card slot the card from my camera fits, I can still have about 1/2 my pictures. If you guys have any input, I'm open
That may be over my head, are you saying I can buy another "computer body" and move the hard drive from my old computer and I can open the old one up off of maybe a USB port?If you do buy a new computer, also purchase an external housing you can install the hard drive fromm the locked up computer in. Then use it as an external drive, search for the "photos" file, or whatever you named it, then copy where you want them.
