I pulled up some carpet and tiled the floor in 2 bathrooms.
I never did Tile before and my little brother has so he helped the process along...
I did have to install new shut off valves which required some ratrod engineering
I built this house back about 95 for a customer. The illegals drove me out of construction which is why I went trucking.
Government HOS regulation prohibiting me from being productive drove me out of the trucking business
I was told by a general contractor that at a certain point it no longer matters how crummy your work is if it's cheap enough.
And then on a big commercial job once where the illegals were working along side me for somewhere around 6 bucks an hour had the gall to say I made more than they do because of my ethnicity.
I blew my stack.
I held up a level and a tape measure and said I make more than you because I can use this
Then I picked up the print and yelled and I make more than you because I can read this
And because nobody has to follow me around fixing everything I do
Most of you bums are dropouts and illiterate in your own damn language and you gots the guts to come here to my home cut my throat working for nothing and cry about how much I make?
I was 27 when I built this house
