Keep it coming, Torchie. I can't imagine any objection to a build thread, but I'll follow no matter where you post. [cl
Thank you good Dr.
If the moderator wants to move it to the build threads that's cool with me.
At this point I am working on the back half of the bottom. This is where most of the pounding takes place so it is prone to more issues. This is also the area of the hull that the boat rides on once it is up on plane.
As can be seen from the pics I am finding more half fast repairs.
The first pics shows an area where 2 planks are butted together. There is a butt block that was factory installed behind this joint. The white spots indicate the factory fasteners. The other bright ones were installed as a stop gap measure. Plus the heads were filled with some sort of epoxy filler which is a PITA to get out of the screw slots.
The other 2 pics show more of the same type of repair. These screws have to come out before I can get to the factory ones.
Thanks for all the comments and for stopping by.
