1929 Essex/Truck
Looking good. Your wasting no time at all. At this rate going for a ride by spring isn't out of the question. Keep at it.
Thanks Gunz, I'm hoping for mid April for a test drive, I kinda put the pressure on myself today by schedualing Sask Vehicle Standarts to come out for the inspection and Vin # issue in a month:eek:
By the way I got a quote for a tinted windshield from Quality Glass in Swift for under $100. tempered side glass for $75 each.
That's one Stout Looking frame....... I like it.
[P [P [P [cl :D
Thanks Torchie
What's not to like. I'm so amazed as to how fast you got all that done. You're not only a master welder but quite an engineer. Fantastic job Doze. [cl
Thanks mdlahotrod, I'm pretty sure I'm not a master welder, I can lay a strip of Dog doodoo real easy:rolleyes:
Big day today, the frame is complete, front end is assembled, frt. brakes installed :D
Now it's time for final assembly.
Question for you? should the tor-in be set at 1/4 or 1/8 inch?
That is indeed one beefy front end. Excellent work.
Thanks mdlahotrod.
Should have another update later today, been working on fuel lines, brake lines and main battery cables. and also a major dung-out of the shop so I could find stuff. Moved two out/board motors, two inboard/outboard motors and a wack of parts to my storage garage.
