deerchooper
- Joined
- Apr 3, 2010
- Messages
- 744
mid 80's 1 ton trucks had a hydro assist brakes that ran off of the power steering pump, i think it also had a brake booster (45% it did) but im not sure.
First off....NICE WORK!!![[dr
Now, with regards to your master cylinder...You might want to take a look at equipment from 1.5-2 ton trucks, etc. I think you'll find one of those will move MORE than adequate fluid-I believe the ones on our older GMC and International buses displace 84 cubic inches. The only possible drawback is that they are designed to be used with a hydroboost unit.
Another point to consider is that calipers and brackets on these biggies are usually interchangeable from wheel to wheel, as well, so you're heading in the right direction.
Thanks for sharing your pics, I'm gonna have to go back and play catch up with your thread!
Regards,
Shea
Are you planning on going with a two piece drive shaft on the truck ?
It looks like with the truck dropped all the way down you will need quite
a tall drive shaft tunnel between you and the passenger.
But with a two piece shaft you could keep the tunnel lower.
A cheap hydro boost system that should work for you would be a early 2000 mustang I would check local yards you should be able to find one. PS great build
Speed, the hydroboost system came on 1996 to 2004 V8 Mustangs. Ford had to put it on to clear the valve covers on the 4.6L modular motors. However for this build, I don't think the MC would be big enough to push the calipers and cylinders that he's using.
Looking good Corpo!!!
