DJ3100
Corpo, I lost the build photos where you could see the brake/clutch from the top when my hard drive crashed. I crawled under and got the best photos I could without jacking it up.
I used the original '53 Chevy pedals and pivot. The gray rod is the clutch actuator. The clutch master is located behind the brake master. The 2 lines are coming out of the hydroboost. Its not leaking even though it looks like it.
Moving toward the rear is another pic showing more of the HB and the master.
A little further back is more of the master. The tube is the tranny crossmember. The clutch cylinder can be seen in the lower left. You can see the residual check valve and maybe a little of the proportioning valve.
The last photos are a couple views from different planes.
The master as well as the brakes I'm using is for an '80 Chevy C-10. Disc/drum.
The HB and the PS pump are from a '99 Chevy 1 ton van. I figured getting the pump off the same vehicle might be a good idea.
The custom hi pressure hydraulic hoses were the only problem, but that's another story.
Hope this helps.
Hope this helps.
