bob w
Always liked the lines of a '37 Chevy coupe. Will you be working on the car all the way to the finish?
I like the low engine/trans mounting. I did mine the same way, I didn't want to cut up the firewall and tunnel, so I kept mine where the SBC was originally. I might have had less exhaust interference if I had of raised mine a couple of inches, but my crank pulley sits dead center of my spring crossmember, 2" above it, so it looks like a factory install.
Thank You Dr. C, for going the extra mile for us.
Much better to see pics.
Never was much on reading books without pics
Work On [P[P[P
Only reason that's called a butt weld is cause it looks like a butt head did it!![]()
Impressive work on the steering. That many angles and no "bumps" is, well, impressive. [cl
I'm pretty sure that steering install would have given me a bald spot from scratching my head. [S[S
Very well done![cl
