I know that the gaps weren't perfect when new but I think there's room for improvement. It only needs to be a little better.
Thanks guys. I beat on it tonight and I'm happy with it. I put a piece of 3" channel across the passenger door opening and one across the top of the door at the rear and a 3" block of wood in the door jam at the bottom rear. Then I pulled the top in with a ratchet strap. That got the twist out. After that I pulled the hinge pins and the plates out of the jams. I bent them a little in the press and put them back together. Now I have 3/16" gap front and rear. [dr[cl. After that I pulled the door latch out and fixed a crack in the linkage and straightened the bent pieces. It works better. Now on to the passenger side.[
Persistence pays off, the other one should go way quicker after doing the first one. [P[P
