A little more done. Motor mounts done. I fixed the profile of the top corners where they meet the frame, they were sticking up above it. I finished the trough for the steering shaft cut the shafts to length and drilled for the through bolts and set screws. Timing chain is in and the engine is painted. I sat the carb and air cleaner on it to see what it would look like. The distributor is stuck in place. I don't like it and am thinking of putting in a Pertronix and coil. The Pertronix looks more stock. I ordered another radiator. I got scammed on the first one I ordered. I'm still wait for the dip stick tube. I will put the oil pump and oil pan on after that is installed. The carb needs a rebuild. That will get done later. I also made patterns for the panels for the firewall and toe board. I need to get to my cousins to use his brake to bend toe board piece. Sorry about being a little long winded, I might be getting a little excited.
