Thanks gents. Not much done today. Had to take the oiler for the Bridgeport apart and clean it out. The oil in it had varnished and plugged up the filter in the bottom of it. I don't know what oil to use in it, I put bar and chain oil in it. I figured it would be stickier than motor oil and stay in place longer. Reworked the lower plates that mount to the frame. I welded a 1/4" spacer to the bottom of them that is tapped for the rubber mounts. I made a bunch of 3/8 OD by 1/2" long sleeves that are threaded 1/4-20 inside to weld into the uprights of the support frame for the tabs that will mount the upper rubber mounts and radiator shell. It's probably over kill but I want them adjustable.
