Plugging away at it. Working on rear suspension. The rear links are cut to length and the inside of the tubes are bored to fit the inserts. The ends of tubes are also cut also cut on an angle so I can weld them to the inserts. The motor mounts are all welded and cleaned up. Next is rear coil over mounts and a Panhard bar setup. [![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
