1937 Packard 115 coupe
Made the last 6 body mounts and built the new floor substructure from 1x2 tube. The forward sections of the floor and toe board will be removable like
the stock floor was, I haven't decided whether to make them steel or plywood like the originals. The hump over the tranny will be steel for sure but I wont make it until the shifter is in its final position farther forward.
attachment.php
attachment.php
attachment.php
attachment.php
    119.5 KB
    117.8 KB
    121.6 KB
    112.8 KB
attachment.php
Time to start work on the rear suspension. If I was building it for myself, it would be 4 link on air - but the owner wants to use stock leaf springs, so that's what it gets. Starting with a decent pair of 37 leafs and original mounts cut from the same year frame, I cut the rear bushings out of their mounts and welded them into the new frame, 2 1/2" higher than stock. Front mounts cut loose and mounted 3" higher than stock, bolts go thru the frame with an access hole on the inside with a 2" tube and doubling plate welded in, a gusset put on top of the mount for extra strength. Looks way high, but it will come down a lot with weight on it, if needed, I'll make lowering mounts on the diff.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
    109.7 KB
    128.4 KB
    116.2 KB
    94.7 KB
    108.1 KB
    89.8 KB
    109.4 KB
    118.2 KB
Working on the rear diff, the ubiquitous Ford 9", this one from a 78 F150. Cut off all mounts, scrubbed off some of the rust and set it on the springs with mounts made from 2x3" tube - not tacked on yet. I need to put on the fenders and tires first to see if the tires are properly centered before drilling the spring locating holes in the mounts.Also need to get some U-bolts made.
attachment.php
Once it's mounted I will need to narrow it so the tires sit right in the wheelwells and change out the axles for 5 on 5 bolt pattern ones instead of the 5 on 5 1/2" truck bolt pattern.
attachment.php
A set of McGaughys traction bars will bolt up, they already have the shock mounts built in to the plates.
attachment.php
    116 KB
    95.4 KB
    98.3 KB
Had U-bolts made, loosely bolted on the traction bars then put on the fenders and tried on some truck wheels to size up the tire centering - need to move ahead a tad. Diff is a little wide, need to take it apart again and locate the wheels I'll be using in the fenders to get a hub to hub measurement to determine how much to narrow the housing.
attachment.php
attachment.php
attachment.php
    105.4 KB
    130.5 KB
    116.1 KB
Mounted the wheels to a set of 5 on 5" large 70's Ford axles I had left from the 36 Packard project and positioned them where I want them.
attachment.php
attachment.php
Put a section of pipe between the axle ends to hold them level, now I'm able to get a proper hub to hub measurement.
attachment.php
The housing needs to be shortened 3 7/8" then I will cut these Summit long spline axles to fit.
attachment.php
    91 KB
    116 KB
    111.2 KB
    137.3 KB
Took out the axles, surprised to find out they are 31 spline and equal length - this presents the opportunity to move the pumpkin over to center it more, better clearance for the driveshaft through the center of the frame.
attachment.php
The Summit axles are 28 spline which is not a problem as I have a new 28 spline Speedway 4;11 posi third member to put in after fab is done.
attachment.php
Made an index line with a zip cut blade to keep the orientation of the cut off piece correct.
attachment.php
The moment of thruth...
attachment.php
No turning back now ! I cut 3 1/8" off left side and 1 1/8" from the right - this puts the center section almost in the middle
attachment.php
My sophisticated clamping system to hold the stub square for tacking in place
attachment.php
All back together, just have to cut the axles on the chop saw.
attachment.php
    151.3 KB
    112.7 KB
    121.3 KB
    142.2 KB
    147.5 KB
    172.4 KB
    151.6 KB
Nice job.
Your cut off saw must cut a lot squarer then mine. Mine seems like the blade kicks out on the heavier metals.
[P [P [P
Ours does too Torchie. I never use it if I want a square cut unless it's smaller stuff.
Can't wait for this build to come together. Looking great so far!
