smallfoot
You'll find it! Something just wiggled on you...[P
How close to full size it that temporary hinge pin? Could it be allowing a bit of sag?
I see the same solution ZZ
[cl
Good example of the "Cause and effect" school of thought.
This points to why some, when chopping a car, get the door gaps perfect then tack weld the doors shut.
I have never done it that way as I always seem to find a need to get into the car.[ddd
Looking good ZZ
You guys are sharp [cl - yeah, it is a bit loose but not the real problem. ( I need to dig around in my junk pile/parts stash to see if I kept some of the old hinges from my 36 to snag a proper pin from)
Today I cut the cowl loose and pulled it back 1/8" and that brought the door up.
But of course that created a new problem- now the door is too tight at the back edge, binding on the latch mech. and door frame.
I can section the back of the door for clearance but that shouldn't be necessary, it used to fit before. As I'm typing this, the light bulb just came on! The cowl needs to come up, not back, so the rear gap is not closed - tomorrows project............[
Fun fact, you adjust the doors on a Model A by shimming the body mounts. Same idea as what you're needing to do at the moment I think.
