Steering came in last week from EZTBucket.
I installed and tweaked until I got everything to fit.
I currently have about 23-24 degrees of steering. My wheel base is gonna end up about 133", so I was hoping for tighter steering, but with spring behind and crossover steering that's about all there is room for.
After I drive it if it's real bad except for parking lots, I could always extend the steering arms 1/4-1/2" to make more room.
What does anyone else have for a turning radius in degrees?
Maybe I should have ordered a 6" drop and spring over? It's hard to tell without an engineering drawing to start with...
I will have about 3" of suspension travel before the axle hits the frame now. I may "C" notch or curve the frame a little later, but thinking it will be enough.
Made some card board templates to start with to save some time. I think I still had a couple hrs. in the first bracket and 15 min. in the second...sigh
I still have ride height adjusting holes where I can go up or down about 1 1/4" if needed.
Hade to make some spacers after I removed the old steering arms because I'm still using drum brakes.
I still need to install and fab brackets for the track bag and the friction shocks. Then I can move on from the front end a bit.
Good news today that I found some used wheels and tires that may fit the bill. I'm gonna see if I can get them stuffed in a rental car if they do...lol
