Old Iron
Well crap
I just knew it was going to work this time [P
Well crap
We are getting closer OI. I believe what is happening is that the pilot bearing adapter is just a bit too long. When we bolt the trans up to the adapter the nose on the trans main shaft goes in to the pilot bearing but the splines on the shaft are pushing against the pilot bearing rim putting pressure on the crank and pushing it out towards the front of the block. Causing a bind. I mean we are talking very small movement here but just enough to lock things up.
When we start to loosen the bolts that hold the trans to the adapter the engine will start to turn over again.
I believe that we have the pilot bearing fully seated so we will take some more off the end of the pilot bearing.
Won't be for a couple of days though.
I thought you were still having trouble with the PP & throwout bearing
I understand now about the input shaft bottoming out on the bearing [P
Sometimes I get a little dense
Torchie, I know you're pretty methodical and careful on this stuff. Is there a possibility that the pilot bushing itself isn't seated all the way into the crank???
Determined to make some progress today I rolled out to the shop and got back down on the floor.
A case of get off your a$$ and get something done, only in reverse. {Just kidding, don't get mad at me.}
Great to hear you got it figgered out.
With the Trans/PP/Pilot bearing issues behind us we got the engine/trans back into the chassis this evening. Interesting with just one guy and me in the chair.
The deep red engine looks great against the Blue/Black firewall color. Don't know what next week holds as I have quite a few Dr appts including my 6 month visit with the Cardiologist. That should be interesting.
Stump is still swollen so I can't get the Brand New leg on. Hopefully will have some answers for that as well.
Thanks for visiting......
