Front End Swap
Swapping the front end to newer stuff wasn't too painful
the biggest thing was getting the old rivets out of the A-Arms... but the angle grinder made it a ton faster then drilling them out.
So just a little FYI for any of you out there that want to do a low buck disk brake swap on yout 60-66 C-10, this may work for other years as well.
I used the front end of an 86 C-10
All you need is: Steering box, Pitman arm, both Spindles.
you can reuse your center link and steering column
You will need new ball joints, upper and lower for the year truck you got the spindles from, they will bolt right up to your old A-arms. You will also need new tie-rod ends.
I also recommend a power-steering bracket from CCP or another company that allows you to bolt up your new steering box to your frame and come with all needed hardware. (This saved me a day of work time of making up a bracket and finding new hardware, it was well worth the $54 I paid for it.)
The swap went very will, I used an old school method of doing the alignment, and it was so good the guy at the tire place asked me where I had my alignment done... I told him.... my dad's garage with a tape measure...
