here`s some info that may help making decisions.
http://www.dodgecharger.com/forum/index.php?topic=104749.0
sweet jeezea lou, peak torque at 2500 rpm. thats driveline breaking torque too. [cl[cl[cl[cl
great video! that center bearing should make a dynamite keychain because it doesnt belong anywhere near a motor haha
Those Drs are a bunch of quacks. And they don't even give you any kind of warranty! That being said I found after 3 knee surgeries that if you kinda do what they say for the first month or so things tend to go better. Hang in there it gets better!!
That cam bearing looks exactly like the ones in my 440, uggggly!
I'm kinda hooked on Mopar power in the long run.
Nice job on the shock mounts. I'm going to file that one away for future use.[cl![]()
I personally have NEVER had good luck with a motor that has set for a long time.
You see all these posts about" This engine hasn't run since 19 blah, blah, blah and it fired up on the first crank with new gas." "And it had 70 lbs of oil pressure and all the cylinders had great compression too."
I guess its just not my type of luck.
Take the time to heal up properly, please. I speak from experience here.
[P [P [P
That 440 will be terrific. Get the rest you need Dozer. [P
Another fine fab job. Excellent pics and the video ain't bad either.
now maybe my wallet will quit bleeding for a while.
Good on the machine shop for quick service.
Are you gonna break it in with the carb?
nice! and I love the fact it has the big Mopar on board [cl
one little thing of consideration... on the trans you may want to replace the seals on the kickdown and gear selector shafts... they tend to leak and are a pain to replace in the car...
WOW! That was fast.[cl
[P [P [P
Yes they were awesome to deal with. And yes I'm going to do the break in with the carb, I know it works and I don't want to add the fuel injection into the mix. I can't afford it right now anyhow.![]()
