DozerII
Thanks Doc I think.
Nice work Dozer!
WOW!
[dr[dr[dr[dr
haha man if there is a problem you can have it! [cl[cl
next time design the mounts to drop the motor out the bottom!good progress!
That 440 looks great. How is that knee doing [S
I'm pretty sure B-tard's "cherry picker" is the same as yours. The reach is too damn short and may find itself modified in the near future! [![]()
I know about those shortcommings. [ddd Mine is too short {cherry picker boom, what did you think I was talking about?} to reach on the long nose Lincoln. First time, I put a piece of box tubing over my boom to extend it a foot. Worked OK, but was hard to keep the back end on the ground. When I pulled the assembly out this time, I used a tie down bar shoved up into the boom. Worked better than the box tube did, but still had to pick it up, drag it forward a foot, sit it down, then go back to the normal boom hookup. Installing will be the reverse, sit it in, put the bar back in and re-hook, then pick it up to put it on the mounts.
Wish I had a rolling A frame, it would be much easier.....
