built a removeable hoop that will hold my steering box for cowl steering. I am unsure if I am going to do under floor pedals or swing pedals. we will see how much space is left once the stering box is mounted. I also am setting up the cab to tilt back on hinges since the engine is set back so far. it will tilt enough to be able to remove the distributor. I plan to insulate the firewall and floor with leftover ceramic insulation from work. small progress but progress nonetheless, I have been giving up motorcycle ride time to work on the truck but a balance is needed
