05snopro440
I have broken one of my rules of fixing.
I fixed two things in the same system without test driving them separately.
Diagnosis is one of the skills of fixing, and you can't learn much about diagnosing if you do shotgun fixing [fixing everything related to the problem]. You probably have fixed the problem but you don't know what the actual problem was, so you still can't fix it next time it happens. I have some diagnostic skills, but want to gain more in my memory library.
Anyhow, I was disappointed in my power steering all along so I changed the rag joint out to a U-joint, and, I changed the high pressure hose to the steering box, as it looked like it had been crushed and I thought maybe the inner lining was blocking the oil flow a bit. If I've fixed the problem I won't know which fix worked.
If you've fixed the problem it doesn't matter which fix worked
