MercuryMac
Builder Junky!
Things went along nicely underneath the truck so the extension housing is back on. Then I crawled up into the cab to put the shifting apparatus back together. Life went sideways, ----- a few times. In the second picture about in the middle, you will see a small hole in the steel block, that a split pin would fit in. Once I got everything lined up and the detent ball in place, I couldn't find where I'd put that split pin, [four months ago]. After a wide ranging search I went to the box of shop supply pins and picked out a good one, and drove it in that hole, fixing the shift block to the shifter rail. I then mounted the gearshift lever and test drove the selection process. By third gear I was thinking positive thoughts, then the gearshift jammed in third and would not budge. I thought the detent ball had jammed and stopped the shifter travel. So, I drove that new split pin down, ---- and it stopped about halfway through the shift rail and wouldn't move any more, even with bigger hammers. I tried drilling that pin out, without much success. Then I screwed a really small tap into the split pin and pried up on it until I broke the tap off in the pin. As I was sitting at the supper table grumbling to Mrs. Mac, I had an epiphany. That proper split pin that I couldn't find was still in the steel shift block down low and when I drove in the second one I pushed the first one down a wee bit so it caught on something under there and now I'm trying to drive it through the top of the transmission case.
I don't know how I'm going to get out of this mess, but at least now I know what I'm fighting against.
