Neverdone
the defiinition of insanity is doing the same thing over and over and expecting different results. You are changing everything a little at a time, there for it is not insanity it is more of a perfectionist approach.
One thing that helps is to do a curved pedal pad or one with a pivot behind it. Then the pad feels flat all the time through the arc. If you do a pivot then add stops behind it so it doesn't move to far. As for the slot in the floor you can add rubber strips to the side of the slot and "seal" it to the pedal as it moves through the arc. Or re-cut it as you said and only have a hole big enough for the shaft. Looking good! [P
Thanks Gus, I jsut saw pics in your thread again, your truck looks killer with that stance...It's looking nice brother.. it's day is coming ...[cl
[P[P[P....![]()
Man you really got to love filling in all them little pieces.
I'm trying to picture what that would look like...got any pictures of it in action?
