Ben Modified
- Joined
- Oct 24, 2015
- Messages
- 387
The oil pressure at cruising, or idling?
The photo was taken at Idle (650 rpm). Pressure cruising is always above 50
My dad did some work on a Prefect for a neighbor that had been hot rodded long ago. It had a radiator from a Datsun pickup that wouldn't keep the 302 cool, but nothing else would fit and the guy didn't want to spend much. So we went through one of his supplier's catalogs and bought the largest heater core they had (it was almost as big as the radiator). Mounted it in a hole in the inner fender and it fixed the cooling issues.
I fitted a smaller water pump pulley on mine, to spin the pump a bit faster at idle and traffic speed. 650 idle sounds a bit low, water is hardly moving.
I also heard that synthetic oil can lower your engine temps quite efficiently, never tried it though.
I battled with overheating on mine for a couple of years but finally fitted a $150 aluminum Summit radiator and all was well. Also added a huge SPAL fan and an electronic temperature controller, and used a 160' thermostat.
....Around town and prolonged idling is only 180-185 degrees. It tends to heat up to the 210 range at the higher highway speeds. My theory is that the turbulence created by the cab roof is preventing the hot air from exiting the engine compartment. ......
[/SIZE]
How is that cooling. I just switched to a new Summit radiator to cool a 350
And things are better.
Sure is coming along nicely...[cl [P
Can you tell me about the AC unit?
I'm thinking of running AC in mine but haven't really found a nice small one.
There's a ton of quality and creative work in this project. Any idea how many hours you have in it?
