Been a mechanic all my life, and have stopped buying tools along time ago except replacement stuff. But the best thing you can do for yourself is buy the best you can afford. This really goes for wrenches and ratchets. If anybody gets hurt with any one type of tool, it's these ones. Cheap wrenches will spread and slip under load, while cheap ratchets skip and give out. The proper way to use either, is to pull while under load, not push. If something breaks, skips, slips, or just plane lets go, you can stop the action a lot quicker if your pulling toward yourself. If your pushing the tool and this happens, your body weight will carry you on through until you connect with something solid, and it will have sharp edges. I have the scars to prove it. I know, can't always do it that way, but try to. As far as screw drivers, I think the cheap ones have genuine lead tips that twist off if you look at them hard. Use screw drivers as screw drivers, not pry bars or chisles. You can get by with less expensive tools that aren't used in an everyday environment, but the real cheap ones will hurt you. Then you have to heal up, and buy a new tool anyway. May as well start with middle of the road stuff in the first place, and work your way up. (By the way, kids bandaids work far better than anything else I've used. They stay on without turning to goop from the grease, oil etc. Just finished up the last of my Whinnie the Pooh bandaids, and now have some with Princess on them. My granddaughters think there great.) Anyway, didn't mean to hijack the thread. Have fun, play safe. Sniper
