A little update:
I was a trooper and stayed in the heat to get the transmission crossmember done. Well, it is done and welded in the frame. I just need to finish welding it to the frame on the underside, because it was late and I didn't feel like jacking up the frame to get under it.
I welded the frame tubes up.
My Cadillac THM400 mount finally came in. It's totally different from a Chevy THM400 if you're wondering.
I cut a section out of the middle of a 1/4" plate and drilled it to mount the mount to.
I trimmed the plate.
I forgot taking pictures of a couple steps. A few steps are going to be shown in one picture. So sorry!
I added two brackets to the transmission mount plate. The brackets had half-circle cut-outs that allowed them to be welded to the tubular crossmember. I also made the center section of the cross member and bolted it in place. With the crossmember ready, I threw everything together.
This is what the center section of the crossmember looks like. Yes, I wear flip flops when I weld and grind steel. It's freaking hot in AZ!
Here it is welded in place. I welded the crossmember such that the transmission angle with the transmission sitting directly on top of the cross member would be 3.5º. This allows me to shim the transmission to the final angle, and I can also drop the transmission 0.5º if I had to.
With this ou of the way, I can start on the front suspension. I'm so excited, I can't wait!
Thanks for looking!
Thanks for looking!
