I like the driver's side with the bent in rocker better than the passenger side. Just trim the bottom of the cab to match - or not.
The ZZ's behind the cab look awesome!
Thank you! I like the look of the bent rocker better also.
I'm thinking an oval fuel tank right in between the rear frame rails would be cool. I like the long rocker myself.
I was also thinking of an oval tank, but on top of the frame rails. I can't put anything in between the frame rails because it will interfere with the suspension push rods.
I really like the look of the tank Dan (DJ3100) has on his truck. I also like the look of '33-34 Dodge gas tanks. Does anybody know what the dimensions are on these tanks?
Looks like your cab is the same as my 39 Chevy. The cab covers the frame naturally with no channel needed . By not channeling I was able to keep the floor nice and sturdy as it came from the factory . I chopped mine 3 " and with me at 5-11 the head room is just right . I also use bomber seats which have the narrow back and lower seat profile . A reg seat and a reg back section would make my interior very crowded . A lot of the available head room is above the top of the windshield ,ducking down to see traffic lights gets old when driving around town . My sunvisor also cuts about 1" from my view , making it the same as a 4" chop . I couldn't drive it if it was any lower .
The rockers hang below the frame. The middle section of the frame is 2"x4" tubing and the rockers are something like 6.5". My plan is to have the truck lay frame, and with the rockers at 6.5", there will be problems. Also, the bent rocker is almost FUBAR.
If I trim the rockers so they're only 1" long and channel the cab 2-3", I'd be able to lay frame without the sheet metal touching the ground, and I'd still cover up the frame rails pretty well.
I'll chop the top the last thing. I want to be sure that I don't end up with a cab that I can't see out of. Like you mentioned, ducking to see traffic lights gets really annoying really quickly.
Your truck is awesome! [cl
The frame I’m planning for my project is along the same line as yours. Nice to see one done, makes me feel a little more confident in what I’m trying.
Thank you!
Your frame looks really nice. Are you going to box it?
