zzrodder
Hope everyone is tinkering away today! Beautiful here today at 57!
I have a couple questions...
I am coupling my 331 to an 700R4. I have the engine adapter plate bolted up and was getting ready to mount the flex plate. The flex plate comes with an aluminum plate this is a slip fit to the crank flange, then the flex plate bolts up to it. After a little clean up of the crank flange the plate fits nicely.
The issue is the bolting, they have a very narrow hex head and came with some nylon locking bolts. Does any know if these hex heads are supposed to between the motor and crank flange pointing outwards towards the trans? Or the other way. It's going to be a bugger to get a wrench between the flex plate and motor to hold these. At least a full head would be easier.....if i can reach. Any ideas?
The second question has to do with my radiator fill cap. My fill cap will be under my nose piece and not accessible. I didn't want to go thru the top of the nose piece with a radiator neck extension. My idea was to put an inline filler cap i the top radiator hose which i bought from summit at the tune of 74.00. It's billet and nice but it may be too close to the edge of the nose piece and feel it's going to interrupt the look of things.
Do I really need that filler? Can I fill thru an overflow like we do on newer vehicles? Will the cap allow antifreeze to go both ways or only out from the radiator to the overflow?
Thanks guys
I'd think that the bolts should go in facing the block - would you even be able to put them in from between the crank flange and the block?? Maybe the narrow heads are for clearance to the torque converter....
With the right cap on the rad, that should work like new cars - fill the rad before the shell goes on, and it should allow you to fill the top tank more - then it can transfer fluid back and forth as needed...
