I think the belt to pulley contact you had w/o the idler was fine.
You wouldn’t want to double back a V belt over an idler like your pic. Serpentine, yes, V belt, no. I know some lawn equipment does use idlers and pulley configurations that put pulleys on the flat part of a V belt, but they use belts made to work that way, regular automotive belts won’t last long set up like that.
Going to sound stupid, but is it possible to run that alt on the other side of the motor?
The belt contact on the crank pulley would be better, and raising the alt higher doesn't look like it would cause a problem. Even if you could rotate the alt upward in its current location would be very helpful.
I am a bit concerned the limited crank pulley contact as it currently is could cause short belt life if there is high demand on the alt.
Crank rotation is clockwise as looking at the picture.
The unique thing about alternators are their ability to run in either direction and still charge.
The cooling fan on it is designed to run in a clockwise direction, it could cause the alternator to run a bit warmer but, not much.
More belt wrap or contact is always a better thing.
Sounds like a plan. You could put your idler pulley on something like a turnbuckle to put outward pressure on the belt. It will be just the same as having a ps or ac pulley in that spot.
Nothing wrong with taking time out to think through a problem. It will save hours of frustration later on if something doesn’t work right the first time.
Chrysler used a V bely idler pulley for a WP belt adjustment back in the late 1970s on the big block cars. The V belt pulley just replaces the flat pulley on the modern flat belt tensioners, and the belt would run in the V like your other pullies. The aftermarket parts companies offered a V belt pulley/bearing as a replacement part, might still be available.
These question threads get all of us old timers thinking again, nothing wrong with that, its good for us. Don't ever be sorry about that.
