MercuryMac
Builder Junky!
And a dang fine picture it is. You passed the test.
Thanks MacAnd a dang fine picture it is. You passed the test.
Thanks OI... Seems I have a real mental block with this. What has me screwed up was I was told at 120 degrees after TDC on #1 the oil holes would line up to prime the drivers side bank. So I'm thinking TDC then use the degree tape to add the 120. Couldn't get them to squirt. I then cranked the drill and turned the crank very slowly until I got oil at the position shown at the picture. I was taping from TDC counter clock wise and I guess I shoulda been taping clockwise. Very confusing....whatda dummy.The timing marks are supposed to go in that order.
The first number to show up is 50 btdc {before top dead center} then they go down from there. The reason is the piston is still coming up in the cylinder as the crank turns.
So Eric at Hot Heads tells me this is a dust cover....ok to spin and won't hurt anything. He said I could remove it if I wanted to.Does anyone know what this gold colored cup of sorts is between the damper and the timing cover? It spins and seems that when the motor is running it would spin and wear something out.
Thanks
Yeppers.... seems a bit silly to me.I found out that Dodge motors have bolt holes that go right into the water jacket.
Thanks Gene.... I'm gona see if there is a complete list. Any idea if the Trans mounting bolts are affected? I've already installed my trans adapter bolting using loctite.Dodge (all Mopar) motors have bolt threads into the water jacket.
Exhaust manifold bolts.
Water pump bolts.
Timing chain cover bolts.
Thermostat housing bolts.
Probably some not right off the top of my head.
Then there is the list of threaded bolt holes in areas that cause an oil leak.
Intake manifold bolts.
Fuel pump bolts.
Rear end covers bolts.
I'm sure I'm missing some from this list as well.
When in doubt, put thread sealant on the bolt threads before you insert them.![]()
The trans mounting bolts at the bell should not go into the water jacket, There was usually extra material at the bell mounting location, but I'm not real informed about the early Hemi.Thanks Gene.... I'm gona see if there is a complete list. Any idea if the Trans mounting bolts are affected? I've already installed my trans adapter bolting using loctite.
