So I talked with Eric at Hot Heads today....really nice guy. Order some more miscellaneous parts. He said if I'm gona run the motor within 2-3 weeks I'm good to go with the first priming. He told me I could crank it a few times with the coil wire off to be safe.
On the rotor position although it could point anywhere as long as I'm synced with the #1 Cylinder at TDC / compression stroke a a good practice is to have the rotor pointing to the #1 cylinder which would be 11:00 on the dizzy looking at it from the rear. So I changed it whata pain. Maybe a good tip....I saw on the Pork that guys use magnet to pull that intermediate shaft and gear up. I used a small long plastic funnel and ground the bottom until it fit tight in the gear bore. Worked very nicely and I didn't have to worry about dropping anything down there.
I got these cast aluminum rocker covers fro Hot Heads and the spark plug tube covers are no longer made to fit those from Tayor. I bought a set from Summit, trimmed down the OD with a sharp scissor then ran them on the disc sander while using a plastic pipe fitting to get a nice 1.650 OD. The fit down in the bore tightly and look decent. Of course another PIA job
I had toget a 2 groove water pump pulley and a stacked crank pully to get my fan belt out a bit cause the single groove was too close and the belt is going to run on the water pump hose.
I have my temporary rack of gauges, switches, wiring to fan, fuel pump, coil and fuel line ran in prep for the run.
I'm hoping I can run this bugger in another week or so, I'm still waiting for my machinist to bang out that alternator bracket.
