Gastrick
Nice rear Bob! That looks fantastick. I think you should bring it to the Turkey Run in Daytona so you can check out Don's sun burnt head. Are those Wheel adapters? If so where did you get them?
Rear assembled & disc's on now... gittin' closer to a *roller*!!! Rollers r GOOD... I'm *really* gittin' fired up now!!! Set pinion angle... weld mounts & put on da big tires... sweet!!!
is that a socket or a square drive lug nut I see there ?
Bob, is that the Ford SVO rear disk kit? If so, that's what I used on my Anglia. They work great. I didn't use the e-brake parts though. I gutted those parts and cut the tabs for them off of the brackets.
Set that thing on top of the engine and take some more pics.
