Neverdone
Looks like it is supposed to be like that!!!! Great job!!
Wow! Ride height needs to go down more.
Sam, "really" [S
Sam I was thinking the same thing on that control arm. Maybe a grommet is in order?
You showed her to always make sure its a good 3/8 to 1/2" thick right?
The lines will also jerk every time you hit the air.
....[P
Probably more than enough. Just gotta make sure you cover all aspects for wear even though the lines are pretty tough. I'm overly cautious since I lay frame, a blown line could get real serious for me.
Since you have air, you should find yourself an old air-horn too!
I gotta say, this is one of my favorite builds on RRR. Mostly because chopping up that year of vehicle ain't easy .... and ain't easy to get right.
I mounted my valves outside of the cab so I didn't have to hear the blow off from letting out the air. Not sure where your valves exit..... even with mufflers its still kind of loud.
You could connect lines on the exhaust side of your valves so they dump out back somewhere - point them down so it blows a big dust cloud every time - bystanders would love that!
