Steam Heat....
Steamed the SB side intermediate frames this morning.
Set up my repurposed Turkey fryer/steamer.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[ddd
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If I did this for a living I would build a legit steam generator.
This is what I know about steaming wood.
Rule of thumb is 1 hour of steam time for each inch of wood thickness.
Box needs to have a free flow of steam and inside temp as close to 212% F. as that's the boiling point of water. At least at my altitude.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If wood has been kiln dried(as most is now a days) it needs to be soaked first.
Amount of soaking time vary's but longer is better. Steaming the wood does NOT put moisture into it. It actually dries it out. But the water from soaking acts as a conduit to allow the heat to go through the wood.
These frames are approx. a 1/2 inch thick so 30 min. in the box.
You have less then a minute once you pull the wood out of the box before the wood starts to loose it's elasticity. So be prepped to work fast.
You may notice that I put blocks under the frame ends. I did that to "Over" bend them to allow for spring back once unclamped.
I will leave these clamped for at least 2 days to make sure they are totally dry and to make the most of the bend process.
That's it for today.
Thanks for checking up on me......
