DJ3100
PA - I'm teaching blacksmithing in a community college welding department.
I took photosto class the other night and found several motor heads. It was interesting.
I solved the carb problem - bought an Edelbrock 500 CFM. Had to run a new wire for the choke and change the fuel line - but no big thing. The new carb seems to run the same or maybe a little better than the old Autolite smog carb.
Next problem: Serious overheating. The coolant level was low, but then I noticed that the upper radiator hose goes up and over the alternator and is above the radiator cap. There's no way to get coolant into that hose and get the air out. (I can't understand why I never saw this problem in the last 12 -14 months it has been the same way.)
The solution is coming from Speedway - an Inline Fill Adapter for the offending hose. It shouuld show up Wednesday or Thursday. Then, on to the next prblem - whatever that is.
