My 46 Chevy Frankenstein project
Got me A bench seat from the junk yard yersterday it is perfect for the 46 chevy cab its A 3rd roll seat out of A plymouth voyager and the dodge caravan has the same seat also, this seat is 45" wide and if you have a realy small cab you can use the 2nd seat and its only 40" wide and has arm rest and center cup holders. with this seat you can still be low and have a cushion for you butt lo.l My cab is chopped 6" and im 6' tall and i going to make mounts to rase the seat 3". here a pic of the 3rd roll seat I got sorry for the poor quality pic.
Got the floor installed today here some pics that are better quality than the last pic.
I desided I wanted it to look more ratty and do something A little different. Im putting spot wellds on ever place on the body Iv had to weld up and I stripped the primer off and coated it with clear stain urethane to make it look antique. I also added some 6ft 5in dia exhaust stacks. the RAT now living up to its name FRANKENSTEIN. I really like the new look![dr
My $4.99 each suicide door hinges I got from an idea on youtube. Most may not like the hinges showing on the outside but I like it and to me its looks older that way.
Pretty cool!
I want to do something like that but with a suicide front axle.
i scored a set of big 6 lug 10"x 22.5" tubeless drop-center wheels to put radials on my f600. f600 is gone but I saved the wheels being hard to find used and $300 apiece new.
They don't make 11.00 x 22.5 rims in 6 lug but i might be able to weld my centers into a set of 11.00 x 22.5's to run used semi truck tires. These are ideas for if I find an old b model mack cab or diamond T or maybe cut up an old deuce and a half.
